Anyone Who Is Using 9power?
kr.r_sniper
nope. placebo effect_ suits only for medical issues... I dont want to say unfounded statement coz im always respect with other's point of views much more in ur personal conclusion. well, its just only my presumption coz i have seen nothing or someone's using here in our place nor i personally tested the same... if that so, well, the gadget theory hit some parts coz magnetic field can also disturb discharge of electricity, in that gadget u shielded-off ur cable, as to form a magnetic shield but only for some inches, how come the inventor's vision and design not shielding the entire length of cable if the desire is to make elec discharge invulnerable to some point against MF? its like (5% shielded, 95% unshielded=still MF vulnerable) hmmm, if that gadget is made and composed of approximately 77% nickel, 16% iron, 5%copper and 2% chromium or molybdenum well, it can be if the entire cable is wrapped... in science it is "MU-METAL/S " which is notable for their high magnetic permeability, can shield up beyond .5 gauss normal MF...
Same FUNCTION of 9Power
A ferrite bead is a passive electric component used to suppress high frequency noise in electronic circuits. It is a specific type of electric choke. Ferrite beads employ the dissipation of high frequency currents in a ferrite ceramic to build high frequency noise suppression devices. Ferrite beads may also be called blocks, cores, rings, EMI filters, or chokes.
kr.r_sniper
What is 9Power (read: NINE Power)?
"CAN HUMAN RESEARCH (HCR)" has managed to create a tool called 9Power (NINE Power). A new breakthrough for all types of machines. 9Power is a simple tool that has the ability SUPER! With this tool, the machine YOU will have the 'Maximum Performance'. 9Power is a technology that revealed the secret of how a unique and simple tool that just plugged in the cable that plugs can maximize ACCELERATION, POWER, SPEED & SAVE YOUR vehicle fuel. This is not a mere figment because 9Power user since 2009 has more than 10 million people to date and continues to grow each day, and Consumers of 10 people, 10 people are satisfied after using 9Power the vehicle was (100% SATISFACTION LEVEL!). 9Power is fit for use for daily use or for long trips, without setting the machine and not damage other spare parts.
What advantages 9Power?
For all engines (motorcycles, cars, water pumps, generators, etc.)
Increase Acceleration, Power and Speed (tested with Dyno Test).
More rapid ignition and good.
Can save fuel (because combustion is more rapid and good, and by way of standard usage, not for racing).
Maintenance-free. Hold Fire / Heat and Water (rain / wash motor).
Plug 'n Go! That is, pairs 9Power it will immediately feel the response is without damage and without the need for another setting.
hopefully TS you already get it...to see is to believe...TY
kr.r_sniper
just like that? (referred in pic), as simple as ring in a finger.. hmmm... cant imagine the additional power unless there's a direct voltage connection from the engine to amplify the spark ... maybe its magic..:rolleyes:, when u believe a certain thing that would be a useful to u, ur faith/mind drives u to a next level of satisfaction...
for me its a psychological bro_ there no such thing that can amplify additional spark to improve acce, fuel effiency, & power unless a gadget like this is connected and powered with the engine electric discharge down to spark plug, i stand "NO" for this coz its really contravene with a simple science.. :D
you can check it here bro :D
http://en.wikipedia.org/wiki/Ferrite_bead
mac kevin
u can also see this link.. about ferrite beads..
http://www.incompliancemag.com/inde...-material-behavior&catid=26:design&Itemid=130
kr.r_sniper
How does it work so as to boost 9Power Acceleration, Power and Speed Vehicle?
How it works is to stabilize 9Power electric current generated by the coil Car / Motor. 9Power focus and eliminate the wild frequency and narrow frequency electric current in the cable plugs to be a point shot into the spark plug so that the resulting fire did not spread it into a sharp and strong unity toward the spark plug to be used as a burning fire. Fire and explosion combustion rates to be very good so there is no gasoline wasted. 9Power also accelerate the flow, so that it can be said as a function 9Power Booster and amplifier currents. The fire produced a steady stream of good (like the Blue Stove with Fire) so that a complete combustion explosion and almost no wasted gasoline molecules. Please note that no vehicles burning gasoline that is 100% perfect. The new motor was out of the factory is only 92% s / d 95%. And only 98% gasoline to burn completely. Combustion chamber was to be clean and any Piston work to be light and stable rhythmic rise and fall, no surprise, and therefore the acceleration is more stable and boost the performance of your vehicle engine. 9Power not have any side effects for short or long term that can harm your vehicle engine.
Bikes can to anything?
9Power can be applied to all types of motorcycles 2 and 4 stroke, Automatic. During sparkplugs head can be released, so long as it can also 9Power inserted. Fingers like wearing rings.
Cars can be for anything?
9Power can be used in the car with gasoline fuel, be it kind or carburetor Matic. 9Power can be used for Diesel-engined cars, but who are already using systems such as Fuel Injection in Diesel Cars .
Can be used for any engine?
Motor, Car, Engine Water Pump, Engine Genset, etc. for the machine using the fuel.
Made of whether 9Power it?
9Power dominant material in the material is and CARBON MANGANESE. Please search at http:/ / id.wikipedia.org or anything from internet.
How long is the life 9Power?
The lifetime of 9Power between 3 s / d 4 years.
How many dimensions 9Power?
Length = 2, 8 cm
Thickness = 0, 4 cm
Diameter (Outer) = 1, 6 Cm
Diameter (in) = 0, 8 cm
Do 9Power be damaged if exposed to water or submerged?
9Power waterproof and heat. Thus, it can be said without treatment.
What if installing more than 1 pcs 9Power in bikes?
There are no negative effects when installing more than 1 pcs 9Power on your bikes. Bikes it will be more stable and much better.
What if installing more than 1 pcs 9Power in Cars?
For car air-Carburetor: each cable plugs use 2 pcs 9Power. For car air-injection: each 1 pcs, but if you pair 2 pcs directly, then it's not a problem.
If the motor has been in-'bore up', wearing Racing CDI, coil and spark plug Racing Racing, it is still able to wear 9Power and feel the benefits?
Of course it could still be over the head of the spark plug is released and it is definitely 9Power benefits obtained.
Is battery could weak after installing 9Power?
Please note that there is no relation between electricity from the battery and Dinamo. For combustion plants, then restored by 9Power came from Dinamo and not from battery. So, if there is a problem in your battery after mounting 9Power, it has nothing to do with 9Power because maybe battery time you were actually replaced.
Why does my Motorcycle engine heat so quickly after installing 9Power?
On some machines Motor, indeed it can happen, but very rarely found. We suggest setting (set of) wind on your motor.
How do I install 9Power in bikes?
9Power very easy to install.
1. Know where the first spark plug in your bikes.
2. Remove the spark plug by pulling the spark plug cover to separate it from the cable.
3. 2 Pcs 9Power to attach cables to the position of 'Arrow' leads to the spark plug.
4. Replace the spark plug.
5. Turn on your engine and hear the engine sound becomes more refined.
6. Test your bikes to determine the instantaneous response is generated.
How do I install 9Power in Cars?
1. Remove the spark plug wires from Delco in one by one so that no one will replace.
2. At the end of the cable plugs are rubber covers. Remove the rubber with a small screwdriver to carefully Rubber cover is torn.
3. Once released, the input end of the cable plugs into the 9Power. Navigate to SPARKPLUGS ARROW. If installing 2 pcs, then it must ARROW in the direction of everything.
4. If 9Power can not enter because of the greatness of the cable terminal, reduce the Tang and press slightly to shrink until 9Power can enter.
5. 9Power push to the end of the cable as close to the spark plug.
6. Replace and feel the difference. If you can not do it yourself, then please go to the nearest Service Station to ask for help from an experienced mechanic.
What are the benefits gained when using 9Power in a motor vehicle?
1. Exhaust emissions are shown to be reduced due to combustion in the engine to be perfect so that the engine became more durable and well maintained. Please prove to conduct emission tests, before and after using 9Power. That means that the exhaust gas to be more environmentally friendly vehicles. Indeed, 9power strongly support the movement of "Go Green". Then help us to provide additional evidence using 9power in your vehicle at a price cheap enough.
2. Traction bikes / car proved to be more lightly.
3. Gas was proven traction seemed to be more long-winded.
4. Proved to be a more powerful engine.
5. Proved to be more fuel efficient.
6. Motorcycle / car proved to be more nimble.
7. Period of time the use of plugs proved to be much longer.
8. Vehicle's engine proved to be better preserved because the combustion of fuel in the engine to be perfect, thus reducing the scale on the machine.
Note: For installation in the car, keep in mind that each person has different experiences to the benefit obtained after installing 9Power in the car because it was caused by engine type, How to use vehicles and vehicle age.
Warning: 9Power not made for racing!
Whether it was 9Power product certification?
9Power are in the process of registration and further testing to obtain the ISO 14001/2004. With ISO 14001 certification, the company can tout itself as a company committed to environmental sustainability. And with that, then access a broader market so when the company's target markets of Europe and America.
chris_mx
Planning to buy this 9power + protect ignition coil w/o ground + brt racing CDI dual band + denso iridium spark plug. Is this combination be safe for everyday use? Will it cost any harm to my smx engine or battery? My smx is stock engine except open pipe. Need some comment to enlighten a newbie like me. Thanks t135 family..
jangbest
I `m not yet using this product 9power, i think it will not harm your engine AFAIK, .... planning to buy soon ....
but to enlighten you up! be carefull to use your RCDI is safer to change your stock valve spring to racing valve spring to avoid valve float racing CDI has no limiter,
casmot
since using 9power i notice and feel a strong current on tension wire when touched, isn't it suppose to be insulated, is this normal
MickO_HCMC
Warning about using aftermarket coils when using BRT RCDI: (see response from BRT below)
Hi Mick
There are so many variations of aftermarket coils and wires, we are uncertain of their quality. Most are not soldered, thus resulting in misfires when hot, potentially damaging the CDI. If racing coils and wires are used, warranty on our CDIs become void.
We do R&D on all our products using standard coil and wire, and found the results to be better than aftermarket coils anyway.
Other than the coil and wire, I really like your modifications!
Kind regards
Burstono Lunardi
