Anyone Who Is Using 9power?
ESOJ de GUZMAN JR
What is 9Power (read: NINE Power)?
"CAN HUMAN RESEARCH (HCR)" has managed to create a tool called 9Power (NINE Power). A new breakthrough for all types of machines. 9Power is a simple tool that has the ability SUPER! With this tool, the machine YOU will have the 'Maximum Performance'. 9Power is a technology that revealed the secret of how a unique and simple tool that just plugged in the cable that plugs can maximize ACCELERATION, POWER, SPEED & SAVE YOUR vehicle fuel. This is not a mere figment because 9Power user since 2009 has more than 10 million people to date and continues to grow each day, and Consumers of 10 people, 10 people are satisfied after using 9Power the vehicle was (100% SATISFACTION LEVEL!). 9Power is fit for use for daily use or for long trips, without setting the machine and not damage other spare parts.
What advantages 9Power?
For all engines (motorcycles, cars, water pumps, generators, etc.)
Increase Acceleration, Power and Speed (tested with Dyno Test).
More rapid ignition and good.
Can save fuel (because combustion is more rapid and good, and by way of standard usage, not for racing).
Maintenance-free. Hold Fire / Heat and Water (rain / wash motor).
Plug 'n Go! That is, pairs 9Power it will immediately feel the response is without damage and without the need for another setting.
mac kevin
just like that? (referred in pic), as simple as ring in a finger.. hmmm... cant imagine the additional power unless there's a direct voltage connection from the engine to amplify the spark ... maybe its magic..:rolleyes:, when u believe a certain thing that would be a useful to u, ur faith/mind drives u to a next level of satisfaction...
for me its a psychological bro_ there no such thing that can amplify additional spark to improve acce, fuel effiency, & power unless a gadget like this is connected and powered with the engine electric discharge down to spark plug, i stand "NO" for this coz its really contravene with a simple science.. :D
placebo effect you mean Mac Kevin? :D
It works more like a magnetic shield for your ignition coil and it doesn't amplify the spark but make the frequency don't arc that much. It actually improves my fuel efficiency to a certain degree and increased response @ 6K RPM which i don't use often. So i will be putting this ring to my Crypton since my MX ignition is already shielded by a copper wire used in measuring my Tachometer. I noticed a big difference when i nstalled my new UMA Digital meter and i believe it is when I wrapped the copper wire around the ignition coil for the tachometer functionality.
mac kevin
nope. placebo effect_ suits only for medical issues... I dont want to say unfounded statement coz im always respect with other's point of views much more in ur personal conclusion. well, its just only my presumption coz i have seen nothing or someone's using here in our place nor i personally tested the same... if that so, well, the gadget theory hit some parts coz magnetic field can also disturb discharge of electricity, in that gadget u shielded-off ur cable, as to form a magnetic shield but only for some inches, how come the inventor's vision and design not shielding the entire length of cable if the desire is to make elec discharge invulnerable to some point against MF? its like (5% shielded, 95% unshielded=still MF vulnerable) hmmm, if that gadget is made and composed of approximately 77% nickel, 16% iron, 5%copper and 2% chromium or molybdenum well, it can be if the entire cable is wrapped... in science it is "MU-METAL/S " which is notable for their high magnetic permeability, can shield up beyond .5 gauss normal MF...
se7en
waiting for other testimonies to be posted here. i myself is interested but still waiting for a concrete proof that it really improves acceleration and fuel efficiency.
ESOJ de GUZMAN JR
iba tlga ngagawa ng alak sir mac.. Tumatalino noh. Hahaha. Ignition coil or 9 power? Well.. I go for 9 power because it is plug n play.. Just remove ur fairing on the right side.. Remove the spark plug socket then insert the 9power apparatos then lock it with tie wire.. Then poof. Its done.. While ignition coil. Much more kalikot todo. Hahaha.
ESOJ de GUZMAN JR
to seven.. You can watch youtube.. For the adik.. You can used same.. Change your ignition coil then install the 9power.. Just a trial n error. Hahah. if not satisfied.. Buy a 15kva step-up transformer from meralco. hahah.
ike
bro where can we buy this and where and how much this item thnks and ride safe
kr.r_sniper
How it will works ^_^
