stator coil protection
JhayBoo
how would you know if u have problems in your stator coil?
im a little bit nervous my tailights always getting busted...mybe there is a shortcircuit when it gets wet am using stock... no rear fender...plate holder only
my headlights kinda blinking also?
just wondering:rolleyes:
does my stator coil got something to do with this?
blinking headlight - have you check your battery level?! stock battery?!
busted tail light - is the replacement original?!
did you modify your wirings?! like fast charging etc....
raksta
new batt..
replacement hmmmm? not original
fast charging etc... am using stock...
:help:
che phags
ok bro ill try, but i wont promis, coz his mechanic is now working in japan,, if he open his engine ill take pics but not sure if when.. try to ask technicians bro they have much info about rewinding.. ride safe bro,
do you have any diagram in rewinding stator coil for lc135?
Sidro
bro cno may diagram or any concept how to rewind stator coil. pa email nalang paji_213@yahoo.com. thanks
pati whole schematic diagram ng wiring with color ng sniper 135. thanks very much.........
regarding rewinding a stator coil, most electricians with experience in rewinding motors knows about this by removing stock magnet wire counting the number of turns per core. just bring your stator to a trusted rewinding shops.. AFAIK
Sonnyjha
mine is already rewind.. almost a 1year still ok and charging normally hehe..
che phags
and where is the location of shop?:)
I'm here at maguindanao province. i dont have any trust in the mechanics here. can u please ask your mechanic on the process of rewinding and i'l do it on my own because the busted stator has been rewind by one of the mechanic here witrh no any diagram ben recorded after he dismantled it. give to me also the number of magnetic wire used. Is it advisable to put electrical enamel on the after it was rewind?
Sidro
Yup but not much, just enough to cover the magnet wires, this will serve and add protection to magnetic wires(electrical varnish other term/s I think). After rewinding of your stator by you mechanic, is it working?
Sidro
the ccause was the use of hid head lamp.
hhmm,, it has some sort of relation, if you install HID not in direct connection to battery or all of your lights is not battery driven. Yes its possible since ballast for HID is also have coils or it is electronic ballast.
Regarding to the diagram for stator coil, I dont know if this available here in the forum. Maybe the best choice for you now is to buy a new 1 and try to compare it with your old and defective 1, because your mechanic got a little messy rewinding your stator. just my own suggestion.;)
