Bore Proper Break In Faito 60mm
jejerome_135
Hi masters, just asking the proper break in for the faito 60mm block i mean the distance that i should have traveled before i go full throttle. My snipee has racing cams, springs, 28mm keihin round and yy pang longy as the mods.
Lester Chua
first when it is intalled.. you can run upto 80kph but be sure you reach this on a slow motion gear by gear, this is for the first 100km... like john_carlo have said earlier its like just breaking-in the stock bore engine but with precautions. when you feel like your engine is some kind hard for it to reach 100kph up your block isn't yet ready. just play your throttle until you reach 200km and when you feel like your engine run smoothly at 100kph then its done!!!
i hope that i've shared you something
GB and Ride safe!
jejerome_135
GB and Ride safe!
thanks bro, this will help a lot :thumbsup:
jejerome_135
no problem sir... just don't be hot on your throttle take it easy and smoothly.. also to add temperature affects improper break-in
what do you mean sir with temperature?is this with overheating the engine? the engine came alive yesterday, and what we are doing now is let it idle for some time before we go on a test run.
sniper135lc
always let the engine idle for more than 5 minutes it also help to sit in the piston rings fast. since gears are already finish on their break-in period. no need to roll out the bike. but still advisable to roll out the bike after a long idle to remove any carbon deposits on top of the piston or rev it high 5 times before turning it off the engine and let it cool down for awhile.
jejerome_135
We did run it on idle for 2 days before rolling it out. We let it idle for some time on those 2 days.
jejerome_135
so far so good, the always on radiator fan really helps, the radiator fins are always cool. Break in route malolos - baliuag, maybe there are t135 brothers that see me, i am riding a fiat replica yamaha sniper. :shag:
