Need Help..how To Change The Auxiliary Light Stator To Battery Connection
thon
bro thon,why do you use diode???
This diode will protect other electronics components from back EMF (High voltage pulse) generated by relay coil when relay supply switch off. If no other electronic components added in parallel with relay coil then diode can be omitted in the circuit.But for me I always put diode across relay coils. 1n4001 diode cost only 1 peso or less.;)
Sidro
What kind of relay is this sir...is this the same that sir thon were saying?or do i have to use two relays? Can you show me a simple diagram please?TIA
its just a standard relay used by four wheel vehicles, you can buy it any automobile shops, even at ace hardware or handy man.:)
thon
Sir, does this means that if the yellow wire is not conected with the rectifier it will automatically fast charge?how it is possible
If yellow wire is not connected the regulator will not be able to shunt excess current from stator to stator winding via yellow wire when regulator set voltage exceeded. :)
Take note our Mc use shunt type regulator.
m.bolado14
this thread is for the one like me who has a broken startor right now!!! but i cant understand the diagram i want this to my sniper cause usually this is the problem of the sniper the mechanic of the yamaha(imus) said to me stator problem!!! plss help me about this problem thx so much!!!!
thon
pwede naman bunutin ang wire from socket instead of cutting it... so if you want to restore your original settings of your electrical you can plug it back again instead of soldering or connecting it with electrical tape. HTH
Its my own way of doing battery operated on my MC sir, just sharing it to others. I can reconnect it back by using soldering iron & shrinkable tube. :p
Reminder: YOU ARE ON ENGLISH SPEAKING SECTION, Please post in ENGLISH!
