Yamaha T135 Bearing Codes
Yamaha T135 Bearing Codes and Oil Seal
Bearings
Crankshaft Left = 6305/C3
Crankshaft Right = 6305/C3
Camshaft (small bearing) = 6001-Z
Camshaft (big bearing) = 6906
Classic tranny 4speed
Transmission =6002
Transmission =6204
Transmission =6004
Transmission =6202
MX tranny 5speed
Transmission =6003
Transmission =6204
Transmission =6004
Transmission =6202
Front Wheel Left =6300-Z/MT
Front Wheel Right =6300-Z/MT
Rear Wheel Left =6301-RS1/MT
Rear Wheel Right=6301-Z/MT
Rear Sprocket Drum =6004-Z/C3
Water Pump bearing =6000
Clutch Plate pressure bearing (handclutch version)= 6901
Oil Seal
kick starter oil seal = 16 x 26 x 5
engine sprocket oil seal = 20 x 35 x 5
waterpump oil seal = 10 x 31 x 13.5
rear mags sprocket oil seal = 26 x 42 x 8
front mags oil seal = 20 x 35 x 7
93102-12891 Oil seal shifter = 12 x 22 x 5
93101-10843 oil seal crankshaft right side = 10 x 18 x 6
Hope that helps guys
the_one
this is great traxxx. tnx for the info.. you can buy a cheaper bearing at any bearing center in your area..
boldstardex
tnx job,thank God I have all those bearings in our auto parts store, if anyone needs help with your bearing needs all of my bearings are made in Japan (koyo and NSK),just pm me. :D
shahril
for the wheel...the best bearing for drag/cupricx, whut brand just want to lightup my wheel... plz help n share.. thanks
guitarizta
sir admin, assuming i will change all the bearings in my front & rear wheel,
the one that i will buy is 2 pcs 6300-Z/MT for the front wheel
then 1 pc 6301-RS1/MT and 1 pc 6004-Z/C3 for the rear am i right?
john_carlo
2pc 6300-z- front mags
2pcs 63o1-rs1- rear mags-since disc ready na yan sir kailangan mo ng isang oil seal jan na ilalagay dun sa may bearing sa disc side para di pasukin ngtubig/dust yung bearing... dalin mo na lang yung spacer at yung bilog nung bearing para masukatyung ilalagay na oilseal
1pcs 6004-z/c3 - sprocet hub
