X1r Head Light Switch....... Please Help..............
Rugzky
hello to all master...
i got a problem when i change my body kit from yamaha sniper to yamaha x1-r..
i need some help to all experienced to solve my problem, please help me how to fix this problem.
no head light switch-----------how to put the head light switch? what should i do?
no park light switch ---------- :(
thank you guys in advace...and really really thank you guys.........mery x-mas & happy new year..
Rugzky
do you have a sample kit papa? custom parklight and headlight switch..what material/tools that i need to prepare or modifying harness too? do you have a simple procedure papa peakabu..?:help: thank you bro...:thumbsup:
EinVer
we are facing the same problem.
for now, I just used a small toggle switch and cable tied it to the clutch cable near the speedo meter.
as for which wire, try to search for a yellow wire on your left hand side, it should be located within the six pin socket
try to disconnect the yellow wire on the six pin socket first, to check if it turns of your headlight/parklights
if it does, then that should be the wire you will need to put the toggle switch to.
alternatively (this is my current setup)
trace the wire from your headlight bulb, we are looking for the LOW beam positive wire
connect a switch there, and your headlight can be turned off when you are on LOW beam.
you will also have an option for the high beam to function as a passing light.
as for the parklights, it will be turned ON all the time. no harm done here, i suppose.
whew, it's really hard for me to explain it here in english. :)
oh by the way, make sure you secure all the wires that your going to connect, specially on the toggle switch,
its a bit hard to connect a wire on those little switches.
as for the materials:
- toggle switch
- a meter or two of wire
- shrink tube or electrical tapes
- blade cutter or scissors
- small cable tie
- a lot of patience
here's mine:
https://www.facebook.com/photo.php?...267645182454.165981.1625802350&type=3&theater
Rugzky
First of all i am glad, because there are so many brother here in t135 are willing to share her knowledge and experiences bout modification, @ papa Eiver "yeah wright", its really hard to speak or explain in English way..but for the benefits of the other forum-er that encountering this kind of matter, oh my god im hit,":sleepy: my nose is bleeding hehe.. to papa carlo, expert in racing boy parts.. AHO what is that mean? sory po papa..
retsam
Ts
You can try to use kawasaki fury's right handle switch. That's what I'm planning for tomorrow.
EinVer
I was thinking of using a raider 150 left handle switch, but now that retsam mentioned it, I think its a better idea.
@retsam - please give us an update on your switch later :)
EinVer
looks good.
how much did it cost you?
id like to use the kill switch as hazard switch
:edited:
Rugzky
Guys happy new year...lets start with faith,love,& Ride safe to all..more mode and blessing to come...... welcome 2013:dance:
