Uma Digital Meter
blackknightrealms
Just installed with some friends pairing it with uma rcdi.now i want to change to brt hyperband.where should i place the rpm line now that uma rcdi will be replace.since uma rcdi has rpm line already available for tapping.
blackknightrealms
Kaya pafs kaso yung thermostat kailangan pang pabutas yung crankcase.and yung para sa rpm.tap mo lang sa white wire ng cable ng rcdi or cdi
ESOJ de GUZMAN JR
tama sir. mali ung nkalaga sa manual na ung rpm ay sa orange wire ng cdi. ung sa thermostat ginawa ko tutal may cover ung radiator ko linagay ko sa upper part ng pagitan ng cover at radiator may space nmn dun. dun mkkta ko temp ng radiator at 70degrees pgkatigil after a second umaandar ung fan.
I already tried running with full tank, but I already running more than 100km the indicator still not moving, that's unusual practice. just now I tested the float with multimeter, there is no abnormal ohm (full position - 8 ohm, empty position 98 ohm)
try to evaluate your floater or maybe stuck up?,try to move your floater up n down if there difference in reading in meter gauge
ESOJ de GUZMAN JR
sori sir blackknight sa late post. hehe,. ito po ung thermostat ng uma digital ko. pwede nmn ung cnasabi mo sa may lagayan ng oil pro pangit kc expose ung wire nya. ito ay basis lng sa temp ng radiator.. prang sa sasakyan dn. pgtumatakbo ang motor nsa 35-40 degrees sya. kng traffic nsa 50degrees ung init. basta normal radiator temp pg tumatakbo ay 35-40. sa umaga un. pag gabi nmn 30 degrees. madaling araw nglalaro sa 28-30degrees. hope this will help kaysa sacrifice ung engine block sa machine shop. iba kc ung size nito sa block (drainage part ng coolant sa bore).
if you want to reset Trip A or B , Tops Speed Record, Oil Mileage counter. simply LONG PRESS ( 3 Seconds is more than enought) THE RIGHT BUTTON (color black ) ubntil the indicator panel shows resets.... HTH. main ODOMETER READING will not reset by using this method...
tanx bro
gunkhean
I found the problem, when i play the float without start the engine, everything is in perfect working condition, but when i start the engine & i play the float, the fuel indicator is inaccurate. Anyone know to solve this problem?
Ajay DC. Castro
this is my uma digital meter. the only thing you can reset is the trip A, trip B, top speed record, oil mileage but the odo cannot reset. when reseting just hold the ADJUST button. the right side for 3secs. if you like to adjust the rpm gauge, time, tire circumference, oil mileage. just hold the SELECT and ADJUST button at the same time. it will appear the RPM adjustment.
menu 1. RPM,
menu 2. lo account - hi account,
menu 3. tire circumference,
menu 4. oil maintenance,
menu 5. time
menu 6. backlight
sir how can i reset nd recorded top speed? is there a reset button for that? it happened that my to my top speed is 297 km due to battery problem. how can i reset that? tia,
ESOJ de GUZMAN JR
Go to the top speed. Then just long press (3secs) the right button. (Select button). When resetting the trip A, trip B, change oil trip just long press the select button. When adjust the rpm, profile, time, contrast. Press the adjust and select button at the same time.
Ajay DC. Castro
than
thanks sir! now i will know if my mc really gain speed after some mods. ^_^
