Tachometer and voltmeter
CarroTT
Hey guys, any ideas of how hot out engines run at ?
I found a place tat sells digital thermosensor tat can detect between 20 to 70 Celcius, very very cheap
clicked
gd qn....mayb we can have 3 meters...tacho,voltmeter,and radiator temp..
i believed the temp measured is the water in the radiator not engine...correct me if im wrong.. :)
CarroTT
the thermosensor is very small, just the size of a matchbox
just nid to place the tiny wired sensor anywhere u wan to check
Mebi can just stick the sensor on the radiator :lol:
i wanna get one, if i dun use it on the bike, i will just use it on my armpits to check if i have a fever :lol:
tsunami
Lol if your bike just a stock bike dont use that tachnometer..No need lor
Change if only you already modify your spec...Good Luck
MioBikerBoyz
clicked they don't cost too much and there are many different series. For the oil, for rpm, for fuel, and what else? But they don't look so good, kinda cheap quality looking. You like em?
Glowplug
clicked said:
Helmie,any idea how the mechanic connect the tachometer? the wire is connect to the sparkplug?
Usually, the input to the tachometer comes from the output of the CDI going to the coil.
As for the temperature, it measures the coolant or water temp range is if you can find from 0 to 100 deg celsius you can use it.
One way to hook up the thermocouple or the sensor is to cut the return line of the radiator hose that's the top hose and put a piece of pipe with the same diameter as the hose and there should be a hole with a thread so that you could screw the sensor.
haen
hi guys, i just suggest to use KOSO digital tachometer, it's an engine pulse tacho, it's accurate and easy to install, i use the TEMP& TACHO 2-in-1, i'd love to post picture but how can i do that ?
