SPEEDOMETER GEAR PROBLEM
boldstardex
Have you experienced seeing your speedometer needle "wiggling" then suddenly it stops moving?here is the problem.:cool:
if you can see the dirty gear inside, that is made up of metal, so it is less likely damged.
heres the culprit!:mad:
if you will notice there is a deep portion in which the plastic gear was eaten away by the metal gear.
probable causes:
*dirt getting inside the gear box
*frequent reverse of your snipy
*too much speed!!!!!!!!!haha:p
Counter measure:
Always check and lubricate your gearbox and speedometer cable
or if it is already too late
you can always buy mio speedometer gear.fits like a charm.:D
hope this helps.:)
ridesafe and GOD bless everyone
john_carlo
probable causes:
Counter measure:
hope this helps.:)
iba ata yung ngipin ng speedometer cap ng mio kasi size 14 ang rim
Sidro
i think the 3rd one is the reason my im using mio gearbox now..hehe
can I barrow that 3rd one? plan to fabricate this and I need a sample for measurement purposes. hehehe,, I already have the engineering plastic I need. (sample na lang kulang). :D
dave36
Mine just wiggling everytime i ride my snipee. But it still functional. Any remedy to it? Its annoying to see it wiggling. -.-
ESOJ de GUZMAN JR
lets just say. grease vs water. this problem occur during rainy season and always washing our mc. and also reversing our mc. buti nlng digital gauge gamit ko. pwede sya sa reverse. heheh
chie
i think your wrong sir, even though your mc is digital, the cable have the same function, you repaced only digital panel not the whole connection like R150 dont have na manual cable. unlike our sniper we use the same cable, if thge cable is damage then your digital meter will not work...:rolleyes::thumbsup:
ESOJ de GUZMAN JR
sbi nila pag more on reverse ang mc masisira ung cable or mapuputol kc ung stock meter ay 1 direction lng sya going front ika nga.. but sa uma digital gauge kng talagang 1 direction din sya same ng stock bkt twing inaatrass ko ung motor ko sir may pumapatak na speed. 1-4km/h depende sa bilis ng pagatrass ng motor. kng 1 direction.. sana wlang na lumabas na speed sa metro. sori for tagalog explanation.. i can prove this sir if my fellow UMA DIGITAL GAUGE user share there experience also.
ESOJ de GUZMAN JR
i will post a thread regarding there digital gauge. if u have friend sir with uma digital gauge. u can try there mc.. hit a like if its true. tnx
boldstardex
uma digital gauge is a very good accessory,however be careful not to get your battery to a low voltage, it will ruin an IC in the gauge which there are no replacement parts afaik.
ESOJ de GUZMAN JR
thank you so much sa info sir.. maybe 2years is good to replace my battery than sacrificing my digital gauge. thanks sir.
ESOJ de GUZMAN JR
ESOJ de GUZMAN JR
ok sir.. get it.. i just like to differentiate the digital and the stock gauge for sniper. both using cable but the difference is the uma,you can reverse your mc in a long stretch but the stock has a limited distance only to prevent from breakage. just like the tacho of yamaha fz. also a digital but using a gear from the front wheel and it has a speedo cable.
