Bore Piston
ESOJ de GUZMAN JR
anyone here tried the 57mm mtrt piston. what is the difference between vixion piston and mtrt piston. im planning to replace only the piston of my vixion kit. is there any tweak to do or just plug n play? is it also ready for stage 2 cam coz the piston is already pocketed? and the performance between the two. vixion piston and mtrt piston.
ESOJ de GUZMAN JR
im using vixion.. i just want to replace to mtrt. only the piston i want to replace.the mtrt is a forged piston like the vixion. what are the possible pros and cons. T.I.A
ianghol
y change vixion piston?..its better than those aftermarket pistons available here in ph..
Mark Anthony H. Baña
you can also do the pocket on your vixion sir If you want to use s2 rcam... or you just wanted the mtrt piston because it's doomed type? try to compare piston hispeed 57mm doomed type to mtrt 57mm doomed type piston sir... ?hehehehe
ianghol
i think..vixion piston is much better than aftermarket piston,,just lacking of some magic touch in it to have more compression:p:D:D:D
ESOJ de GUZMAN JR
the real magic.... basta d ka smallin ng raider150. ok na yan. mapa plug n play man basta umabot ng 140km/h . ok na yan. remember speed kills. ang motor may pyesa.. ang tao wala.. ride safe always.. Pray first before leaving..
Gie
additional, don't forget to wear safety gears.. wag gayahin ang mga rider na "organ donor"... riding without helmet, minsan may helmet nga pero nasa braso naman nakalagay... ok nadin yung di kabilisan ang motor di naman kasi tayo nasa race track palagi, hehehehe OT...:D
ianghol
ang raider mabilis yan kahit nka sniper ako..hahaha
ang raider from kasa mka 140kph yan..
ang sniper, hindi kaya 140 nyan..
kainlangan pa magic para ma pantayan ang 140 ng raider..
in short..d kaya ng raider na pang service ang smx ko..hahahaha:eek::eek::D:D:p:p
mag bore man sya ng 70mm long ride morethan 100km..hahahaha:D:D:eek::eek:
ot na ot:D:D
