ESOJ de GUZMAN JR
upon reading. i learned this.Sir im a newbie,how about if ur set up is vixion kit,brt dualband rcdi,r valve spring,uma clutch spring,uma highcam,uma plug coil,ferrox airfilter...so,what is the pj and mj for stock carb? Old sniper hand clutch...tnxs
*Notes/Tips: If You Increase the piston Size By 1mm, You Also Need To Increase The Size Of Main Jet By One Size.
(Example: Standard = 100 > Increase To 101). Use the closes jetting size available.
. MX user here all stock after market exhaust only.
