can anyone help me with these? how can i minimize the vibration of the plastics,, or its better if i can fix it and get rid of the odd vibrating noise, thank you..
wheel interrior rubber is cheapertom snipes said:run a belt made of polyester across the leg shield, will solve your old age problem on vibration , done all previous tips but this one is lasting...
Het Goff, you mentioned designed clips. Can you recommend any? Just had the fairings wrapped and some of the clips are not attaching well anymore resulting in the rattling.try using an old rubber inner tube, like from a bicycle. it's thin enough to be placed between the two body parts. also, try to make sure you don't pop the screw when tighting it too much. it will weaken the clip the the screw is being secured to. i have this problem, i need to replace all the clips with a better designed clip.
