Repsol Moto Racing 4T 10W40 & 10W50
It is the ideal synthetic lubricant oil for very high performance 4-stroke engines. Its formula ensures maximum protection for all engine components, with special emphasis on the clutch and gearbox. Its efficiency is reflected in the reduced friction of the engine components and maximum power is maintained at all times. The results have been proven at the highest level in both national and international competitions under extreme conditions with specially prepared and standard bikes. It performs equally well on the road and on the racetrack.
Quality level
API SJ
JASO T-903:2006 MA & MA2
Repsol Moto Racing 4T 5W-40
Quality level
API SJ
Repsol Moto Racing HMEOC 4T 10W30
Synthetic lubricant oil for high performance 4-stroke engines with fuel saving properties. High thermal stability and excellent engine care as it is used at high engine revolutions even under high temperatures in hot climates. It particularly cares for the delicate parts such as the gearbox and wet clutches. With Racing HMEOC your engine is always ready to give maximum performance.
Quality level
HMEOC (High Quality Motorcycle Engine Oil Conception for Fuel Saving)
JASO T-903:2006 MA
API SJ
Repsol Moto Sintético 4T 10W40
It is the most suitable synthetic lubricant oil for modern 4-stroke engines. It provides maximum protection for medium and high cylinder capacity engines with one, two, three or four cylinders, and ensures the care of all its components and the proper lubrication of oil bath clutches. It is doubtless an oil which enables first-time response from the engine.
Quality level
API SJ
JASO T 903:2006 MA2
Repsol Moto Supersport 4T 10W30
Synthetic lubricating oil for 4-stroke engines, offering excellent protection and cleanliness in high performance engines at high revolutions. Designed to meet the requirements of the biggest European and Japanese manufacturers, where these recommend viscosity grade SAE 10W30.
Quality level
JASO T-903:2006 MA2 (Code M034RYL002)
API SM
Repsol Moto Sport 4T 10W40
It is the perfect semi-synthetic lubricant oil for 4-stroke engines. It provides high thermal stability and its viscosity level facilitates ignition at different ambient temperatures. Repsol Moto Sport is perfect for bikes that are parked out of doors at night or which are driven in areas with varying weather conditions. And, of course, it guarantees optimum lubrication of the different engine parts and less wear of its components.
Quality level
API SJ
JASO T 903:2006 MA
Repsol Moto Rider 4T 10W40, 15W50 & 20W50
Lubricant oil for low, medium and high cylinder capacity 4-stroke engines. Due to its special composition, Repsol Moto Rider is particularly suitable for driving long distances without worrying about performance loss or premature wear of the different engine components in very different situations. It is therefore ideal, among other uses, for making long journeys as it is not necessary to monitor consumption as often given the oil's special viscosity.
Quality level
API SJ
JASO T 903:2006 MA
Repsol Moto Town 4T 20W50
Refined lubricant oil especially designed for 4-stroke petrol engine motorcycles the greater part of whose activity is developed in an urban environment. Its additives prolong its life in this type of working conditions.
Quality level
* API SF
