did some mods today
what i want to happen is to install the tzr 250 mags in front.
since the mags is wide, it cannot fit to the stock front of t135.
in order to fir it, the TPOST needs to be changed to a wider one.
the stock TPOST has only 120mm left fork to right fork.
the newer TPOST i installed have 150mm
much wider!
the new TPOSt i used is from SYM Grand Dink 150 scooter.
what we will do is remove the Vertical pipe of the stock t135 tpost
and install it in the Kymco Grand dink tpost bracket.
the t135 vertical pipe is direct fit with the grand dink tpost bracket.
much wider!
