HOLPARTS COIL AND PROGRAMMABLE CDI
haen
CDI DC 350V UNIVERSAL PROGRAMABLE
Feature
·Universal For Every Motorcycle’s
·Programable With Keypad
·Programable With Computer ( interface for easy programming)
·Ignition Curve per 100 rpm ( 1000 rpm up to 13500 rpm )
·Adjustable Pick up pulser Advancer
·Selectable Pick Up Pulser Signal Type
·Extended Pick Up Pulser Advancer
·High and stable voltage 350v/vdc,High Voltage 350V over 40000 rpm )
..Advanced Low Voltage Protection
·Low Power Consumtion (50 ma at 1500 rpm ,1,5a At 50000 rpm )
·Builth by SMPS Technology use for Heavy Industries
..Powered by NXP founded by Philips semi conductor
CDI DC 475V UNIVERSAL PROGRAMABLE
Feature
·Dual Ignition Map
..Selectable Pick Up Pulser Signal Type
·High and stable voltage 475v/vdc,High Voltage 475V over 40000 rpm )
·High Energy System
·Advanced Low Voltage Protection
·Powered by NXP founded by Philips semi conductor
CDI DC 600V UNIVERSAL PROGRAMABLE
Feature
·16 Ignition Map
·High and stable voltage 600v/vdc,High Voltage 600V over 40000 rpm )
·High Energy System and X2 Supported
http://img5
08.imageshack.us/img508/5416/coilsmallpm4.th.jpg
http://img100.
imageshack.us/img100/8498/cp350vtf3.th.jpg
http://img
100.imageshack.us/img100/4837/cp350rs232bl9.th.jpg
http://im
g107.imageshack.us/img107/4861/cp350keypadlx9.th.jpg
AND THE COIL ONLY SPARK RESULT
http://img
107.imageshack.us/img107/839/testresultsg0.th.jpg
I'm on Indonesia..
contact my cell phone at +628157179198 or Yahoo messenger ID haentiara
for pricing
haen
yea.. so pick the most suitable CDI.. usually we use 350V spark.. over than 350V was used for bored up and racing engine..
the coil and CDI has been used in race in my country...
haen
What is SMPS? SMPS stands for switch mode power supply. In this supply power handling electronic components are continuously switching on and off with high frequency in order to provide the transfer of electric power via energy storage components (inductors and capacitors). By varying duty cycle, frequency or a relative phase of these transitions average value of output voltage or current is controlled . The frequency range of an SMPS is from 20 kHz to several MHz.
