bhek_21
REVISED as of Nov. 13, 2012
This diagram is based on the idea of our fellow riders out there. I just compiled them for our guidance, enlightenment and to help our fellow riders who wants to make DIY or just have information what was done in HID installation. But some installer may or may not applied this installation that I posted in their previous installation but you can still apply this if you haven't.
The idea of this diagram is this.
I've put the actual wiring diagram of HID kit.. It's just plug and play..
but you need to change your system to battery operated.
Note:
Cut the yellow-red wire going to your headlight switch and secure the it with electrical tape.
Other mechanics cut the yellow-red wire near the stator.
- When you are using your HID, Fast charging will commence.
- When you are not using your HID, normal charging will commence.
but you need to change your system to battery operated.Note:
im just not good in this electrical wirings.. but my mechanic did cut the yellow wire in the rectifier and my parklyt was always getting busted then after a month or two my HID was installed, my battery always drains.. i charged it til 11.8V then after a week it was already drain then i charged again and got drained again in less than a week.. i changed my mechanic and he said that the earlier mechanic didnt cut a wire.. i think its the yellow wire connecting to the stator (i think).. then he said my lights would get busted if that wire wasnt cut.. my friend then said it wont get drain again but if it does, maybe there's something wrong with my battery.. after 3days my battery got drained again
