sixty-thirty
hello, i have recently installed a racing boy rear break system . the problem seems to be , the wheel dose not lock when i press , i have to press really really hard for it to stop. can some one help me with this issue .
This is quite normal with newly installed Disc Rotors and Brake pads, Remember riding your bike brand new? You won't have your front brake for shit.how long dose it usually take . i installed the sysyem on 13/06/2016 , last monday ...
same experienced sir, last month i replaced a brand new front break rotor (300mm) and a new pads,.... then tried after installing result was not gripping pretty hard.... after a few kilometers of running, and now it grip pretty good but i need to bleed my front brake for it has a free play on the leverhello, i have recently installed a racing boy rear break system . the problem seems to be , the wheel dose not lock when i press , i have to press really really hard for it to stop. can some one help me with this issue .
That squeeky sound you are getting is due to brake pads grinding against the residue built from braking.had to remake the spaces for the size and it seems to get better (useable on the street)
