hELP...White Smoke Came Out!!
arechin
hELP...
i need sum help here..
those anyone know y my exhaust appear that white smoke like 2 stroke bike...but less..not a heavy smoke..
sum of my frens said if it happens,then sumthing goes wrong with my pistons..is it correct?
then..wat should i do?
:( im really broke now to change another piston..
:cry:
goff_d_p
what oil are you useing? how old is the exhaust?
is there fiber inside the pipe? it might be just the fiber burning and setteling into the muffler . did you have any trouble before installing the pipe? if not then it's eather the pipe of the gasket.
Mas Catoer
Really? What did you do da lovely bike?
Hmmm..
Check first if s'body unintentionally put oil into the muffler.
The smoke might disappear after few minutes.
Or the gas contain any oil. Empty the tank and refuel it.
If you still have it then it could have some problem such as:
- Broken piston ring
- worn out piston
- Cracking piston head (due to valve collision)
- Valve seal problem or the inlet valve itself.
That is what I know :) :)
Others will help you then
Cheers Bro.
kamalez
Check the exhaust first. Remove the pipe and start the bike. At least you would know the white smoke is from the engine or the exhaust chamber.
From there you able to identify
kirana
ITS YOUEr BLOC gasket bro,so some coolent will go in your bloc and your machine!!!!!!!!!! just change your gasket,4T oil, top up coolent
miobikerboys
Contributions to the smoke could possibly be:
1: fried pistons
2: wrong oil usage
I had the same problem when my pistons fried, the sound was terrible and smoke would only come when the bike was in nuetral. Whats your bike condition now?
rooster
if its white most comin out all da time its likely coz of sum oil get burned in da combustion chamber..
if its only on hi rpm...its ok
miobikerboys
hey arechin, your bike is still new right? GET CLAIM BRO!!!! unless you already modified it alot outside of the warrantee then your f*#ked.
tsunami
i suggest if you wanna change your psiton better change racing bloc hehe one shoot for more power n nevertheless
if white smoke appears on high rpm..
your bike piston rings not bedding in properly during running in...
if smoke appears everytime...
1. blowby
how old are your bike??
odometer??
tsunami
"yeah and whatever you do, DO NOT USE SHARK RACING BLOCKS, THEY ARE SHIT! Bad quality, rusts and too heavy"
what do you means by those phase Mio.. is it really not good. So whats type is good any.....
kamalez
Arechin - Any update on your bike problem
Tony - Could give us a review on the racing block - material, quality- of course not in this thread
tsunami
uncle Bad could you post a thread show your big bore bloc box...what brand you use...all products have name is it
arechin
1: fried pistons
2: wrong oil usage
same here mio..
its came out when after im speeding,then stop by at the traffic light,then tho smoke came out..
but when i warm up the engine..its start with black smoke..with a few ram,then its gone..
arechin
sorry guys..
juz got back from my village for last raya celebration..
hmm..
my bike still got same prob..after im speeding,its came out..then,gone..
n my bikes engine sound like not same as in stock mode..coz my cousin also have same bike n i tried to compare with her..mine n her engine..n she got smooth engine till now..
