Hazard Light
thon
is the stock flasher relay needs to be replaced also?
yes bro if you are still using stock signal light bulbs since stock flasher can handle only 20watts but if your using LED signal light, theres no need to replace the stock flasher relay.
yves
hehehe,, its patented I think.. haha,,
Costings:
Relay 2pcs = 175 petot/each:p (second hand)
Wires(50meters) = 500petot 1 spool..:eek:
PCB 2"x3" = 65.50petot per square inch:eek:
Diode 5pcs = 200petot/each:eek:
thon talent fee = 3k (credit card accepted):D
Consultant Fee(ako) = 1k (free massage)
Total Costing = paki na lang.:D
There you go yves, I give some idea on the costings.. haha,, pis
ha ha ha! the price is right!
jcm1130
can i replace my stock signal light with LEDs?.. i already have a hazard lights just using my stock signal light assy, no other wires and gadgets installed..
thon
thon sir, can I use parklight LEDs for the signal light or they are different?
@guitarizta They have different connection bro . You can make your LED park light as signal light by connecting signal light wiring to parklight (front) but park light function will be disabled. If you want both parklight and signal lights on but with working signal light then theres a need to modify wiring , i will post diagram later..:)
guitarizta
Forgive me for my 1st question sir, what i mean to say is I have LED parklight bulbs in hand, can I put them in the signal light socket and serve as signal light? Or i should buy LED bulbs that are really for signal lights?
thon
Park light and signal light have the same socket. You can use that LED as signal light.;)
eckz08
sir thon i already have a hazard light on my bike. my mechanic put another flasher relay with 3 pole that connects to ground, key switch and to new switch(single contact) while other one is connected to the signal light. my question is it still possible for the connection that i have now to make the hazard is disable when signal is switch on the hazard is enable again if the signal is switch off. hope you can help me. TIA. :)
thon
@ eckz08 No sir, it's not possible. Use 1 DPDT relay and 1 dpdt switch. You can follow the diagram posted in this thread.
eckz08
so you mean to say i need to change all of the connections using dpdt switch and 2 spdt relays like the diagram you posted in the first page. spdt relays- bosch relay would do am i right? anyway, thanks a lot sir thon.
thon
Yes bro. 1 DPDT and 2 spdt relays.:)
