Mamaw!new bore, new piston , new hi speed conrod ,above all new copper gasket 65mm perfect fit on every curve...from traxx...thanks
Welcome broThank you sir for the cms cams
is sir axon from tarlac??is sir axon same person name turbo?new bore, new piston , new hi speed conrod ,above all new copper gasket 65mm perfect fit on every curve...from traxx...thanks
kung yun turbo ba na sinasabi mo is from concepcion tarlac yes i met him once lang aksiidente pa, but egv i don't know sorry OT na yata kami admin job...ahh kala ko sir from tarlac kayo si turbo kilala nyo sir?sino masmagaling egv or turbo sir?
maybe we can use the chat box instead ,
tnx
wow!! how much 65mm copper gasket, the one without the water port holes?now available.
why this gasket have water ports? 65mm x1r block does not have water ports on top of bore.new bore, new piston , new hi speed conrod ,above all new copper gasket 65mm perfect fit on every curve...from traxx...thanks
same price doc.wow!! how much 65mm copper gasket, the one without the water port holes?
different brand/design.why this gasket have water ports? 65mm x1r block does not have water ports on top of bore.
