performance bro? is it noisy?i'm using faito s4 ev.. stock bore..... tik tik tik tik.......
sir ur a faito turbo user?? is there modification need to b4 or upon installing the faito turbo cams?? r u on stock bore??me tOooo.... satisfied faito user turbo cam![]()
yes faito turbo cams user and faito 60mm block.sir ur a faito turbo user?? is there modification need to b4 or upon installing the faito turbo cams?? r u on stock bore??
umm.. if i use turbo cams wid stock bore?? is it advicesable?? or eni modification needed??yes faito turbo cams user and faito 60mm block.
bro its ok to use the faito turbo camshaft to stock block. but make sure your engine piston have a deep valve packet, or modify your engine block. that's may opinionumm.. if i use turbo cams wid stock bore?? is it advicesable?? or eni modification needed??
ok sir.. wer did you buy the cams and block? and how much?bro its ok to use the faito turbo camshaft to stock block. but make sure your engine piston have a deep valve packet, or modify your engine block. that's may opinion
NICE INFOall of the ff cams below are plug and play on vixion/stockbore135
-kawahara k1
-faito s4 evo
-faito low cam advanced (dont follow advanced setting instruction in label)
plug and play means no pocketing on piston needed.
hehehehe maybe i use s4-evo for my stock bore
me to because of you.. BI hahaha.. peace papiNICE INFOhehehehe maybe i use s4-evo for my stock bore
