Engine Oil
charge
Shell Advanced is semi-synthetic. For normal usage it is good enough.
I prefer full synthetic because my engine always cold start and always can't fully warm up before reaching destination. Full synthetic can provide much better protection under this condition, as semi-synthetic oil is thicker at cold temperature. I was using Motul semi-synthetic 15W-40 and it is pretty good after the engine has warm up.
Now changed to Royal Purple 5W-30, the cold start is excellent and the engine response is better at low rpm. I can use 1/4 throttle to reach maximum RPM fairly quick even the engine has not warm up. My next target would be Royal Purple 5W-20 or Mobil1 0W-30.
Some real good oil that I've tried on my old EX5:
Hi-rev 5W-40
Car engine oil 4L, i get it around RM90 and market price RM150. engine can start with only one kick when the bike is left untouched for 1.5weeks. Used for 9 months without problem.
The bike can easily rev up to max RPM, can even overshoot slightly and the engine won't felt stressful at all.
Some recommendations (full synthetic):
1. Castrol Syntec 0W-30, RM40 per quad.
2. Mobil1 0W-20, RM37 per quad.
3. Redline 5W-20, RM55 per quad.
Price taken from: http://www.myoilstore.com/
arechin
so bro charge,
according to the link u post there,
which one is better 4 my engine..
its hard for me to start it when in the morning to warm it up..
wat is quart exactly?
dude_pare01
its the temperature range you can use the oil
w stands for winter,number before it is the lowest temperature you can use the oil and the other one (20) is the highest temperature you can use it..thats ambient temperature or outside temperature...
the higher the range..the more stable the oil in temperature changes..but the more additives it has
arechin
oohh..
thx dude for ur info..
now i get it..
so,im decide to change it to 5W20 lorr..
can or not?
i mean izit ok or not?
arechin
really? :shock:
dat wat im using b4..
i didnt mention bout dis before..
so,as u told me ryte now,then..
im not ganna use it anymore..
dude_pare01
better if you can find repsol...works great...mineral based but the same price as semi sythetics...
i use my bike daily so i may change to repsol syntetico(semi-synth) anytime soon
arechin
im using my bike within my work place n ma home for the distance at least 80Km for a day..
its mean go n back..izit i need to change my engine oil after each 2k km or wat? n now there sum noisy at my engine..n its not sound smooth anymore..
dude_pare01
yeah...cost the same as a castrol...160 php, shell vsx cost about 200 php
and repsol mineral based cost 250 php..its semi synth(sintetico) cost 500+ php and repsol racing oil is about 650+ php
charge
actually all oil (mineral, semi or full) have the same viscosity at 100C. So it wont really burn ur clutch when engine is warmed up. I have used very thin oil for long and the clutch is still working damn fine ;)
Lower viscosity oil provides good protection when the engine is COLD. Cold in thesense that, the engine hasnt reached the operating temperature yet. Modern engine are designed to work at 100C (Tat's why we cool with water). For air-cooled bike, higher rating is recommended because the engine might go beyond 100C, but 135LC has water cooling, the engine is always running at around 100C when warm up. So no nit worry about the clutch burnt or slippage. The lower rating the better in terms of engine protection, as our engine wear n tear is the most when it is cold :)
arechin
according to u..
wat kind of engine oil u used now?
n how was it?
dude_pare01
repsol mineral based...its good...but i want to try the semi-synth just to know if its better...been riding a lot and revving a lot...checked my oil and still amber...nice
