Y
Yama-Yama_35_GR
Guest
Hello everybody!
I am an owner of a Yamaha Crypton X T135 (Greek model).
I have 1.400 km on the odometer (It is new, i bought it last August)
Although it is new i have a significant problem with my gear box.
When i start the engine every morning, i always let it work for about 5 minutes idle.
Then when i put the 1st gear it kicks like a dunkey... Sometimes i cant put the 2nd gear due to bad clutching...
When the engine worms up the problem is a little bit solved but it still has problem when i change the gears....Some times i can't put ANY gear while driving.
I am anxious about this problem because the bike is new and i am the only driver (a carefull one...) of it.
Is it a reason for taking it for some repair at Yamaha Service?
After the oil change (at 1.000 km) i thought that it might stop, but it didn't.
Also, i drove it for the first 1.000 km with extreme caution about the required RPM's or KM's that Yamaha says for the correct function-running of the engine.
If someone has a suggestion for my problem please answer.
Thanx a lot!!!
Thanx a lot!!!
