Con Rod bearing failure
kamalez
Who has exprience bearing conrod failure, i had on mine cost me to overhaul the engine. The mechanic told me the oil hole for the conrod is small thus oil was not properly lubricate the bearing causing to fail
This has caused the block wall scratched
m00nraker
like wat happen to my sniper.. my con rod failed to. i had replace all the bearings in the con rod including my block en piston set.. because my block have been damage by the piston hope ur mc can be fix soon...
kamalez
The mechanic has fixed it , a new conrod, bearing others has to be changed which has cost me a bump,
Also the mechanic has modified the new conrod installed by widening the oil hole for enhance lubricant
kamalez
it is in break in period now and since the overhaul is done i took the opportunity to change valve spring, cam and 150FZI block
CarroTT
well u will see if it will work or not
i did widen the oil channel to the cam bearings, widen the oil channel on both sides for the piston shaft and also added twice as much holes to the oil ring channel of the piston when i was still fooling around with my wave. But i never felt the necessity to widen the hole on the conrod bearing as it is well very much lubricated. nothing seized on my wave
but it was mostly my own intuition when i was doing my mods.
m00nraker
your bike now is even better i envy you hehe
my conrod bearing also failed after two years of abuse :)
my block is scratched too... :-(
thats why i was not able to ride my bike on sniper ride
i will openup my engine this week and also install 21t 4th gear too
haen
better cryo process ur bearing while u r doing it for longer life time.. also the conrod too..
raider125jeigh
maybe its really time to upgrade your 4th gear.. hehehe..
any advised prior for the conrod bearing to be faulty i mean nitial problems you encounter... any pics for that... thanks
CarroTT
or maybe its time to upgrade your bike, traxx
do the maths, it might worth more to get another new faster bike
rather den fixing a busted modified one with more expensive mods
consider the vixion, u might like it
but its real boring to live with a vixion, i warn u first :lol:
@marlock
i will just wont crank
@haen
how i wish :)
@raider
no initial problems, days before that i was traveling long distance with no problem.. probably its just the end of it :) hehehe
@carott
hahaha maybe its high time to use R125 engine on my bike :0
hass
For better lubrificate you can make one better oil Flo with one stainless filter :
Or deeper drill the hole in the filter house
russell
oh.... stainless oil filter!!!!want that one. where we can buy it? how much does it cost? is it safe to use in our bike?
hass
For the mark is PC flo .
The price is beetween 15 and 20$ without shipping
You find this filter by lot of mark (pc flo , scott .....) but you need to know there is just one builder and the difference beetween mark is just the price (from 15$ to 90$ for the same model ) .
If that safe for the motor :
You can have to 7 more flow before open the oil by-pass , there is lesser restriction than oem filter with better filtration .
hass
Just one question :
Can you find Liqui moly product like Mos2 additiv or motor oil with MOs2 in your country ?
