Cms Cam Vs Kawahara K1 Vs Faito (s4 Evo & Turbo) Vs Uma High Cam
John Jordan
To all masters & veterans out there who experienced using or at least drove an lc135 with these cams, what's your comment, in terms of performance and installation?
JapSpeed
I did 140kph many times on my trial run... by the way I know @Gerry Jaloro personally, we are in one spot here in Bacolod and he never tried his bike on long roads... on his daily route yes my bike runs 130+ too...
John Jordan
if you want to use your stock carb, better to change your stock jets 1 step higher..
Just as I thought! 140kph on a stock bore and stroke that's impressive, I wonder if I can get the same TS with my planned out mods. Cant wait to finalize my list of goodies. I'm still at a lost between the cams.
John Jordan
I've been reading some post and it seems that everybody opts for CMS in which I've been considering to just ditch the other options and go for it. My other concern lay on the pocketing as well as to how many mm cause finding a good mechanic here is a job. But, I'll still give it a little more time to weigh things.
JapSpeed
sir @JapSpeed, is s4-evo plug & play? If so, whats your valve clearance on it? s4-evo is stage 1 right?
not totally plug & play (optional) for removing the decom assy... mine i removed it... right now i use 8in 10out... normal tik2x sound, i tried 10in 13out tolerable tik2x sound...
John Jordan
I see. So, removing the decompression pin is a must. S4 evo is really hustle free compared to CMS. How long have you been using your S4 evo sir?
JapSpeed
just awhile ago... less than 1 month... disadvantage of not using decompression is little bit hard on starting, worst when using big bore... the only hassle on CMS cams is the piston pocketing, but once you did that bye2x hassle... maybe next month i will try CMS cams... but still my current cam is good for me...:p:):thumbsup:
John Jordan
Haha. "just a while ago" huh? Pretty clever. Went for 140kph again sir? If I only know a trust worthy mechanic here then I would really extend my patience and get CMS. But know I am quite tempted to go ahead and buy the S4 evo. Haha :rolleyes::D
JapSpeed
if i will try my TS these days, then i can predict it can hit 200kph...haha... bagyo Ompong is here...
