bridgestone battlax Bt-39
fo33il
woho...bt39..so far ive seen,theres quite numbers of singaporean who using this tire...(observation from singaporebikes)....hehehe
edit: it is my observation from singaporebikes forum...
AbgSotongzz
traxxas-modifier said:
guys
anyone of you have tried or used Bridgestone Battlax BT-39 tire for your motorcycle, t135 or not?
thanks
Ive tried using tis wondrful tyres on the 135 and the results was excellent! Dont need to worry bout cornering,be it wet surface or even thin sand,it wont even skid an inch! Not for oil surface of course! Go down the corners til you scratch those knees but the tires will still stick,itz lyk glue on the tarmac bro! Tanx to the technology of soft compound! Only two disadvantage to reconsider,itz heavy and the smallest size is 80/90.. But i stil recommend tis tyre for those whom are corner fanatics.. Guess wat? u still can scrap those pipes wit or without pillion with confidence! Can imagine how low you can go?? No worries at all! For a 17inch rim,i recommend front 80/90 back 90/80! Dat will do it all.. Asta la vista babeh!!!!
tsunami
dont worry to take laps or overlaps but must worry about your bikes might became slower than stock tire
AbgSotongzz
rudduan said:
no its not.look carefully......i think duro who copy the battlax tread design....
Ur rite bro..N bcoz of dat many ppl mistake duro for battlax.. From itz tread to the quality.. They tot duro have the same quality as battlax juz bcoz it have the same thread.. Well,wen u try it den u know it.. After a hard riding,u could feel the stickyness on a battlax but stil the smooth surface on a duro.. Try it out bros to have the feel of a battlax grip.. Cheers!
Mas Catoer
Battlax still da most popular and prestigious tire among them who love speeding here. totally strong grip. but need to change it every 6-7 months. Then FDR is next to it.
135lcSS
umm...i cant afford a battlax tyre for me...its RM240++ sumthing...the tyre is like a viva brand tyre...what's battlax tyre is so special??..
mjaltamira56
here in the philippines we use BT-39 SS for racing purposes.. its performance is really great.. i think it could match the quality of FDR tires.. Before i used Vee Rubber gekko star crcuit compound tires... but when i tried Batllax its much better on fast and tight corners...
jain
but have u'll tried michelin sporty?
Hi all,
have anyone try michelin sporty? i want to change tyre but dun know whether to change to BT 39 or michelin sporty? pls give comment thxs...
