xclickclickx
Hey Guys just thought id share with you my new malossified bike
My performance parts are:
63mm malossi
CMS 22in-19ex valves
Ported head
ported manifold
APPI valve springs
CMS Cam shaft (no decompression setup)
BRT dual band cdi
AHM pipe customized
Devil muffler (soon changing to a KTM muffler)
UNI air filter outer foam soaked in Air filter oil (i use to have K&N but when i saw my old piston obviously little bits of dust were getting sucked through)
Removed ASI system
Carb is a secret !! Ill show you later!!
My tappet clearance is
.010 in - 0.14ex
head bolts torqued down at 22nm (2.2 m.kg, 16ft.lb)
63mm malossi
Ported head
ported manifold
APPI valve springs
BRT dual band cdi
AHM pipe customized
Removed ASI system
.010 in - 0.14ex
, does anyone know know whats the best sort of ignition coil, Hotwire, spark plug combination is and what sort of extra HP I would get out of it, if any? been looking at Nology full Ignition setup, at the moment im running complete stock ignition set up with a side gaped sparkplug, and i indexed my spark plug as well when my head was off.
(blue anodized aluminum)
