Sniper Mx Rear Hub Issue!
raziel
Good day to all and a happy new year advance.
Sir please do help me, i bought a hub set for smx and the rear hub fits but the spokes doesnt and the spokes hits the caliper. Any remedies for the said issue?? TIA!
snypey16
much better if you post some pics.
CLYDE
Naexperience ko to, put one or two pieces flat washer between the hub and disc plate, pro tatabasan mo washer (curve din style) pra ndi cya lumabas sa hub pag kinabit
CLYDE
kung dikit pa din kahit me washer, igrind ng konti ang left side ng disc pad pra mas lumayo sa rayos ang caliper. see pics below
raziel
@CLYDE
KUYA still the same the spokes are still hitting my caliper my brother tried as wat u have said...any other remedy besides wat u have said earlier, by the way are u using the standard spacers or standard sprocket holder?
raziel
@CLYDE
KUYA what bracket have u use for your rear hub smx? I've notice you weren't using the standard bracket. Maybe thats the reason why i cant make it fit.
CLYDE
rear disc conversion kit lang gamit ko pro yung hub pang sonic ata yan na disc ready tlaga. Maybe mx swingarm is wider than sniper classic kaya di magfit, wala imposible sa magaling magconvert, try other shops
snypey16
sir ano po ang maker ng sonic?
raziel
@CLYDE
I see so ur motor isnt smx? Kundi sniper i see anyways thanks for the reply mamats kuya CLYDE.
@snypey16 honda sonic rs 125 limited edition but pwede made to order.
BigBird
Paps is this issue already sorted out? What I can recommend is just to change your disc brake with bigger diameter and the bracket. On that way, your caliper will have more distance from the hub.
raziel
@B.I.G.B.I.R.D kuya thank you its already been sorted out, the only thing is i have grind the brake pad for it to fit. Anyway i'll try your suggestion kuya. Thank you! GBUA
