Sniper Mx 150 Engine Problem?
Exniper
Hello po, I hope I'm not misleading everyone with my thread title. I am worried about my snipeee. Eto po yung mga problems ko. Gusto ko lang magka idea bago ako ulit bumalik sa casa para naman baka may ma suggest ako na gawin nila. @1.8k odo at the moment. Usual speed 70-100kph (marami kasing aso dito)
1. During Nagaaccelerate ako may sounds na borrrrrrrrrrrrrrgggggggggggggggggggggggggggggg pero kung maintain speed lang wala naman xang sounds. Tinalian ko na yung siren ni mot2 para d na gumalaw baka kasi yung ang tumutunog pero same parin guys.
2. Napansin ko rin, naka first gear ako maintaining @3k-4k RPM may naririnig ako na parang naggrind like eto ang sounds. grrrrrrrrggg....grrrrrrgggg... ggrrrrrrgg... grrrggggrrg..... pati sa 2nd gear ganyan din pero sa 3rd at 4th wala naman. wala naman eto nung bago pa si snipee.
3. Napansin ko rin kahit naka full clutch na ako naka close throttle bago mag shift, lumalagiting or parang miss shifting ang lumalabas pag nagshishift ako either low or high gears. Takot na ako baka napano na yung friction plates or mga gears sa loob.
4. Yung Lagitik na sounds which sir japs have already explained na normal lang baka valve lang. The heavier the sounds the faster.
Pa help guys, baka may explaination kau neto :D
JapSpeed
dalhin mo nalang sa casa bro.. parang di normal yng mga sounds na yn..
ike
saan b location mo paps ksi kung malapit k lng d2 antipolo meron akong mech. para sa mx king ksi last month pina tune up ko sa kanya yong motor ko i hope it helps bro
K3rn
You may bring to other 3s shop that shouldn't void the warranty, since I did for my sniper's maintenance I always bring it to my preferred branch as recommended by other owners since they have mechanics...
polokpolok
hello sir! does your engine problem solved a
Sorry, we are talking about taking my sniper150 to another 3s shop for 2nd opinion.
hello sir! is it solved?
