No Head Light & Tail Light,,,battery Going To Run Out,no Charging
guitarizta
john_carlo thanks paps, 1 more thing...when the yellow/red wire is cut the voltage current must rise is that right? if not is it considered a defective rectifier already?
john_carlo
yup it may exceed 15V... not all problem with poor charge cause by the recti sometimes stator coil... or dead battery.. or too much electricals accesories is on
john_carlo
how to check the stator coil paps if it is functioning correctly?
either there high charge or no charge at all. no charge MC will not start even in kickstart with no battery.. overcharge even there is a recti it cannot control the charge even if the wiring of recti is Stock
guitarizta
ok paps, thanks for the info...I experienced a strange behavior of my HID last night that's why I'm asking.
Last night after parking my mc, my HID is blinking for a while even it is not switched on. I don't know what happened but I'm thinking of maybe there is something went grounded with my electricals coz it rained last night and my MC got wet but not really a heavy rain. Do you have any idea what is the reason?
john_carlo
ithink there is a faulty/grounded wiring... maybe due to rain.. better check the wiring that is cionnected to the HID switch put some shrinkable tube if there is its better than electical when joining wire
guitarizta
ok paps...will do checking tomorrow of all the electricals luckily i still have some spare shrinkable tube left...thanks again and ride safe..
fmark
hi, sorry to post here even the problem of TS is solved. i have almost the same charging problem, but when HID is off, i can only get 6volts. but when HID is on, it went up to 18volts. is there something wrong with my rectifier or stator?TIA
thon
Try to use rectifier from other sniper bro, if voltage goes back to 12v-14.5v when HID is off after using other rectifier then your rectifier is busted.:)
fmark
yes. maybe thats the reason why my battery always drying up.(low battery solution) do you know if there is an aftermarket rectifier for sniper?
