Omar Ghan A. Saluan
Sniper Classsic Racing cams are same with LC135 Racing cams? nhihilo kasi ako sa suplier ko. help guys plzzzz.....
yes the sameSniper Classsic Racing cams are same with LC135 Racing cams? nhihilo kasi ako sa suplier ko. help guys plzzzz.....
sir saan ang location mo?sir, valve clearance depends on the lift of your camshaft. You have re adjust over and over till you get the lowest possible output for better performance. try starting on 9-13, 10-15, 13-18. make sure your valves isn't hitting your piston or else it's another heck of a problem...
valve pockets? not necessarily, faito cams 2 low cam advance (low lift but advance cam duration) i guess 5.8mm lift or not exceeding 6mm, if you are UMA R3 cams user... valve pocketing is advisable..good day!
Please advise, I've been planning to buy this, faito low cam advance II. Is this effective on stock bore? and base on what I've read I need to pocket my piston to 4mm or 5mm which is right? and do I need to change my carb to 28mm and PNP my head?
/thanks..
