arjaythegreat
I am having this problem of limiting sound on my carburetor after installing 60mm faito borekit, ported, sun racing valve spring, 28mm carb, racing cdi, faito turbo cams. Pls help how to solve this problem.
What do you mean limiting... Sun racing valve spring is a no good aftermarket part as I remember there is a member here that blew the engine due to this partI am having this problem of limiting sound on my carburetor after installing 60mm faito borekit, ported, sun racing valve spring, 28mm carb, racing cdi, faito turbo cams. Pls help how to solve this problem.
change your valve spring to vixion, cms, hispeed, tk and those valves spring that were tested and proven already by some members and veterans here before you blew your engine offJust like a squeeking sound on the carburetor. Its like having a limiter on a stock cdi. I have notice thqt sun valve spring is too soft than the stock right before we installed it. But I said why would they make that if its not for that so we didnt hesitate on installing it.
btw put air cleaner in your carb to minimize the sound from your carbyJust like a squeeking sound on the carburetor. Its like having a limiter on a stock cdi. I have notice thqt sun valve spring is too soft than the stock right before we installed it. But I said why would they make that if its not for that so we didnt hesitate on installing it.
I suggest you change also that spring because it only carry a 10k rpm beyond that it will valve float... New year is coming kaboom!!!!!!!!........Thanks to everyone who helped. Problem solved. Changed sun valve spring to stock. Sun valve spring very soft.
Now im having aproblem about ng exhaust valve stick. My mechanic blew it! He had bended my exhaust valves. Now I need to replace them. Anyone selling 2ndhand exh valve stick? Pls recommend me one. Txt 09127404655 las pinas area
Do you remember the size of your sun racing valve springs? As far as I know, thermostat is normally closed when not on use, like you said, your mechanic told you that it is closed. It is only open when coolant is at high temp. around 80 degrees Celsius enough to open and widely open during very high temp 100 degrees.check this out paps..this is from http://www.yamahat135.com/threads/blow-up-engine.16165/
OT may i ask you guys if it is ok to remove the thermostat? i encountered blow up engine, my block and cylinder head had been seriously damaged, something that you cant imagine, as per my mechanic the main cause of this is my valve spring (sun valvespring) is too soft its valve floated and kiss the piston and his 2nd oppinion is that the engine overheated. the water pump is ok but he noticed that the thermostat when he pulled it out is closed and he think that this is also the reason why i overheated. and i tell him that my sensor in pannel did not flash but the sensor is working properly so as the radiator fan.
damaged: block, piston smashed, cylinder head, 2 exhaust valve head removed from its stem, connecting rod bend and lots of granules of the piston and cylinder wall and valve tip is inside the main engine. in total, its a DISASTER!!! pls reffer to the pic.
this is john carlo imperial engine using sun valve spring..![]()
