suplado010
mga sir help naman po kung anong klaseng led pang tail light ng t135 ang fit sa bike naten..kasi hindi kasya yung standard nah bulb..napancin ko kasi mas mahaba yung stock bulb naten..help naman mga sir...TIA
sir kasya po bah yan sa tail light ng snifey naten?kasi nakabile ako yung standard hindi nagkasya sa tail light ko e..pinagcompare ko yung pwet nung stock tail light ko tsaka yung led nah nabile ko mas mahaba yung stock..Nakabili na kaya ng LED tail light si ts.
@ts bro kung ganito LED tail light hanap mo, marami nito sa caloocan.
View attachment 14756View attachment 14757
Kasya yan bro. Kung bibili ka sa caloocan dalhin mo nalang stock tail light bulb mo para maicompare mo yong sukat.sir kasya po bah yan sa tail light ng snifey naten?kasi nakabile ako yung standard hindi nagkasya sa tail light ko e..pinagcompare ko yung pwet nung stock tail light ko tsaka yung led nah nabile ko mas mahaba yung stock..
DI DAW NAGBEBENTA SI astroboy06try mo kay astroboy meron p yata cya tinda led tail lyt eh
oo bro, yung sa kin dati eh yung pang head light na LED.DI DAW NAGBEBENTA SI astroboy06
bro, i have a led tailyt bulb, my problem is if i push my brake on, it does not illuminate an extra light.. its already too bright when i use as a parklight.. in short, i cant distinguish if brake light on or not..Kasya yan bro. Kung bibili ka sa caloocan dalhin mo nalang stock tail light bulb mo para maicompare mo yong sukat.![]()
you have to made some adjustment on the wiring bro... you have to swap some wirings in the socket... if which color so sorry that i dont remember...bro, i have a led tailyt bulb, my problem is if i push my brake on, it does not illuminate an extra light.. its already too bright when i use as a parklight.. in short, i cant distinguish if brake light on or not..
@jcm1130 possible cause of this is busted built in resistor of your LED tailight. You can add resistor on your park light connection bro to lessen the brightness of your park light.bro, i have a led tailyt bulb, my problem is if i push my brake on, it does not illuminate an extra light.. its already too bright when i use as a parklight.. in short, i cant distinguish if brake light on or not..
appreciated the insights bro..@jcm1130 possible cause of this is busted built in resistor of your LED tailight. You can add resistor on your park light connection bro to lessen the brightness of your park light.
Cut the parklight connector then add 120 ohms resistor 1 watt. The higher ther value of resistor the lesser the brightness.
You can check manually your LED parklight/brake light by directing the bullb connection to the battery, if both pins/terminal have the same brightness then built in parklight resistor is already busted.
one more thing bro, if i were to buy a new led tailyt bulb, do i still need to add a resistor?..Nakabili na kaya ng LED tail light si ts.
No need to add resistor bro. Led tail lights have built in resistor.one more thing bro, if i were to buy a new led tailyt bulb, do i still need to add a resistor?..
Just install current regulator bro but adding resistor in series is possible.thon bro, how about LED parklights...the resistors of the one's that I bought is like burned I assume the built-in resistor is too low to handle the current (correct me if I am mistaken).
Q: is it possible to add another resistor besides the one that is built-in the the LED parklight in order to lessen the electricity load to avoid burnt resistors? if so, what value of resistor should I buy?
