Hi beam blow, low bean working
bloh
i have changed the front bulb 3rd time....every time change about a few weeks. the Hi Beam blow and Low Beam still working.....anyone know what happend? Appreciate.
bloh
unlimited express said:
maybe theres something wrong on the voltage and its higher than 12 VDC.
I suggest you buy a H.I.D. bulbs.
I used stanley bulb....the Stock builb last for 1 1/2 years then blowed. later bulb blow for hi beam....all 12v bulb..
trying to get the HID bulb.....
anyone sifu got this problems?? wiring? or battery?
kamalez
I had this problem in my old bike and after changing the rectifier the problem solved. Perhaps this will help
bloh
mmm.....rectifier......is the normal motorhshop can change it or yamaha dealer shop?
kamalez
you want the orginal which will more expensive go to yamaha dealer or spare parts shops.
If can use the not original parts then go with motorbike spare part shops
charge
HID on bike is illegal (I guess). The non-HID white lamp that I've installed already blocked by police for checking.
phl6684
u open ur front head panel...u c a yellow wire which is connect like Y..then try 2 pull the wire n then put it back..i think it`s a bit loose(longgar).
hope this help..
bloh
hope this help..
wil try that...thanks
