goff_d_p
While looking for the YZF-R4 I discovered something new.
Make Model- Yamaha FZ8
Year- 2010
Engine- Liquid cooled, four stroke, Forward-inclined transverse four cylinder, DOHC,
Capacity- 779
Bore x Stroke- 68.0×53.6mm
Compression Ratio- 12.0 : 1
Induction- Electronic Fuel Injection
Ignition / Starting- Transistorized coil ignition / Electric
Lubrication system Wet sump -Clutch Wet,multiple-disc coil spring
Max Power - 78.1KW 106.2 hp @ 10000 rpm
Max Torque- 82.0 Nm 8.4 kg-fm @ 8000 rpm
Transmission / Drive- 6 Speed / Chain
Gear Ratio- 1st gear 2.692(35/13) / 2nd gear 2.063(33/16) / 3rd gear 1.762(37/21) / 4th gear 1.522(35/23) / 5th gear 1.350(27/20) / 6th gear 1.208(29/24)
Frame Diamond frame
Front Suspension- Telescopic fork 130mm wheel travel.
Rear Suspension- Swingarm (link suspension) 130mm wheel travel. Caster angle 25º Trail 109mm
Rear Brakes- 2x 310mm disc
Front Brakes Single 267mm disc
Front Tyre- 120/70 ZR17
Rear Tyre- 180/55 ZR17
Seat Hieght 815mm
Wet-Weight- 211kg / ABS 216kg
Fuel Capacity- 17 Litres
The wheels are five-spoke cast aluminium rims – the front tyre is a 120/70 ZR17, and the rear is a 180/55 ZR17. This gives both bikes outstanding ride feeling, grip and cornering performance, with access to the full range of sports rubber. The riding position is sporty but comfortable, with a seat height of 815mm and a narrow tank which gives the rider a good ground access. Overall ride experience is compact and light, with generous room for manoeuvring. Steering is quick and responsive, with an extended 33-degree left-to-right steering angle - making tight U-turns and peak-hour traffic busting much easier. Muscular, mass-forward design The FZ8-series consists of two models – the naked FZ8 and the semi-faired Fazer8 with a front cowl and screen. A short muffler, narrow tank and new 3-part tank cover instantly distinguish these bikes from their peers. Visually, the FZ8 series evokes a pure release of energy in forward motion. The black side parts on the tank provide comfortable knee grip, and give the subtle impression that the coloured tank is breaking away and accelerating forward. The headlight unit on the naked FZ8 adds an aggressive-looking detail. In all, the visual impression is of a bike that looks fast even when it’s standing still – and that sensually curved diamond frame and muscular 4-cylinder engine are still the stars of the show.
Accessories A range of genuine Yamaha functional and styling accessories is available to enhance the looks and extend the capabilities of the FZ8 and Fazer8. The range includes : • Higher windscreen for the Fazer8
• Stylish flyscreen for the FZ8
• Seat cover • Subcowling
• Rear carrier
• 46L Topcase
• Passenger backrest for 46L topcase
• Innerbag for 46L topcase
• Grip heaters MC 120
• Passenger grab bars for the FZ8
• Main stand • Radiator cover
• Engine guards
• Roller protectors
• Stylish license plate holder (available in April 2010)
• Tankpad • Stylish LED indicators in black, chrome and carbon look (available end May 2010)
• TF Touring tank bag for the Fazer8
• TF City tank bag for the FZ8 Apparel Yamaha offers a wide range of apparel, designed to keep riders and passengers stylish and protected. The apparel range includes the following riding gear among others:
Year- 2010
Capacity- 779
Frame Diamond frame
Seat Hieght 815mm
• Rear carrier
• 46L Topcase
• Engine guards
• Roller protectors
